why system variables change automatically?
Hi, some of my system variables change its value automatically. I am glad to know the reason? Thank you
Joe-Bouza
I would guess there are basically two types
Program crash and error traps do not have time to re-set FILEDIA is a classic example
The second unknown applications modifying you environment behind the scene. For example you may be modifying your space but your system administrator may be running setup files so he knows everyone's setup
Joe Bouza
Thank you
I am not interested in the reason it happens, I am interested it stopping the system variables from changing.
WarrenGeissler
@Anonymous - You can't stop it from happening but you can protect yourself and have an extra reset button by using the SYSVARMONITOR.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
I am using that its just annoying when are pickstyle value changes and move and escape don't work like we normally use them. I have changed the values to the preferred values we use which makes it a quick fix, but the variables that change that we aren't sure of are the problem. Was just hoping there was a way to lock the changes from happening all together.
bhuddleston
Did anyone ever figure out what was causing this and fix it? If so, what is the resolution? We have one computer that resets variable 7 to 8 times a day.
