While loop error in LISP Routine
jdebruynkops
jdebruynkops
the goal of this LISP routine is to input 3 values: the wattage of a solar module (str), the number of areas (int), and tracker (aka string) type (int) (either a 2 or a 3) and output a series of layers named:
"G-ANNO-GCR_AREA 1_XXX(watts)_XX(strings)" ..., "G-ANNO-GCR_AREA N_XXX(watts)_XX(strings)" depending on the int inputted for number of areas. I'm having trouble getting the code to work, I think its a problem with my while loop. this is the error I am getting:
Here is my code:
;;MAKEGCRLAYERS - Lisp routine to replace the tedious process of making GCR Layers
(defun c:MAKEGCRLAYERS()
(setq watts (getstring "\nEnter module wattage :"))
(setq areas_int (getint "\nEnter number of areas :"))
(setq tracker (getstring "\nEnter type of tracker :"))
(setq text " ")
(while (> areas_int 0)
(setq areas_str (itoa areas_int));; makes string version of areas variable
(setq text strcat("G-ANNO-GCR_AREA " areas_str "_" watts "_0" tracker));; combines all strings into correct format
(if (not (tblsearch "layer" text)) (command "-LAYER" "N" text "");; Makes a new layer
(setq areas_int (- areas 1));; decreases areas_int variable by 1
GKNIGHT892NE
Have you tried to decrease your count outside of the while loop?
andrewpuller3811
You are missing a closing parenthesis for you if statement.
Should it be -
(if (not (tblsearch "layer" text)) (command "-LAYER" "N" text ""));; Makes a new layer
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
user181
I see three problems, see below.  Did my response in your last post help, you never replied?
(setq text (strcat"G-ANNO-GCR_AREA " areas_str "_" watts "_0" tracker));;   The parenthesis needs to be before strcat
(if (not (tblsearch "layer" text)) (command "-LAYER" "N" text ""));;   You forgot a parenthesis at the end
(setq areas_int (- areas_int 1));;   You didn't put _int after areas
jdebruynkops
You my friend are an autolisp genius!
