Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Where to start?
Where to start?
Hi everyone.
I've recently been made redundant from my job & I'm wondering where to go from now. I've got a New Zealand Certificate in Civil Engineering but I'm a bit stuck in the dark ages with regard to draughting & design using CAD so see this as an area that I should look to upskill in as even the jobs I'm otherwise over qualified for all seem to require it now.
Civil 3D seems to be the most appropriate package that I could do with knowing so I'm wondering if this is an appropriate place to start or should I start with AutoCAD & work my way up to it?
My other question is to do with getting the SW. Ideally I want to be able to learn from the Autodesk online resources so I can work through it in my own time & as fast as possible but it looks like the only way to get an educational copy of the SW to learn with is to be enrolled with an educational institution. Is this correct or can I get approval for this somehow?
Any advice would be gratefully appreciated.
Brian
Joe-Bouza
Autocad knowledge is helpful to leard civil3d but you can learn them simutaneously. If you plan to stick with civil work I would encourage lrearning it. Don't know what SW is
Joe Bouza
Jeff_M
Joe, SW would be SoftWare....
neilyj666
You can get a 30 day trial but that is not ideal.I think autodesk did something for people in your situation but not sure if they still do
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
jmayo-EE
Civil 3D runs on top of AutoCAD. You will need AutoCAD skills to be successful with Civil 3D.
If you get the demo versions get AutoCAD first. Start with the tutorials that come in the AutoCAD Help drop downs. Use YouTube to assist where you struggle or want more info. After you have a good working knowledge of drafting lines, curves, polylines, text, dimensions, page layouts and plotting you should be ready to go to Civil 3D and do the same.
There are also great blogs with additional info, great tips, tricks and workflows.
John Mayo
AllenJessup
No. The program was cancelled.
Allen
Allen Jessup
CAD Manager - Designer
AllenJessup
That's about it and I believe it has to be an accredited institution. You might look for a vocational training outfit and just take a class in AutoCAD. Then you could download the free trials.
You might also investigate if there are on-line courses that would qualify you for the student software.
Allen
Allen Jessup
