Solved by Jeew-m. Go to Solution.
Dear Friend,
I would rather answer the first two parts.
Student version is for learners. If you need to do professional work you should get the full version.
As I know there is no difference in the display or the capabilities of the software whether you use student or full version. But when you print your work in a student software it will embed a text that the drawing is created from a student version.
Full add on list is available here.
https://apps.autodesk.com/CIV3D/en/Home/Index
