What is a "plain end" fitting in pressure networks?
mermerCAD
mermerCAD
In this Autodesk Knowledge Network article about why pressure pipe runs break, it says one cause is "using plain-end Fittings to connect between Pipes".  What is a plain-end fitting?
https://knowledge.autodesk.com/support/civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/Unsup...
Thanks so much!
Meredith Chamberlain
C3D 2022.2
paul.kazmerzak
Well, I don't know about the C3D world, but in the real world, a plain end fitting is when the end of a pipe has the same size OD on both ends.  Compare that to a "bell end" pipe that has one larger end that fits over the smaller end of the previously installed pipe.  Plain end fittings require a coupler to join to other plain end fittings.
mermerCAD
Thank you @paul.kazmerzak !  That is exactly what I was looking for.  Now things make more sense to me.
I really appreciate your help!
Meredith
