What does a Surface become outdated, and hence need rebuild?
soonhui
Advisor Advisor
soonhui
The documentation says that
 If the surface definition is out-of-date, is displayed next to its node in the Prospector tree.
But what does out of date mean, exactly?
After I rebuild a surface, and then I start to add or delete vertex ( or line), will that render the surface out of date? Under what circumstances will the software deem the surface is out dated?
Secondly, if I now rebuild the surface again, what will happen? Will the software replace all the lines with the internal generated one, hence overriding the lines that I manually add?
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
AllenJessup
Any change to the Surface, Edit or change to the data used to build the Surface, will make the Surface Out-of-Date. A rebuild will not eliminate your edits. It will take them into account when rebuilding. Everything that is checked in the lower pane will be used for each rebuild.
One way to avoid this is to set the Surface to Rebuild Automatically. The downside is that a rebuild can take some time with large or complicated Surfaces
Allen Jessup
CAD Manager - Designer
neilyj666
....and to add to @AllenJessup reply, the surface is rebuilt in the order top to bottom so the outer boundary (if you have one) would usually be the last entry
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
