Warning when saving in Civil 3D 2015
When saving a file in Civil 3D 2015 the attached warning appears.  The file does save, but i would like to remove the persistent warning.
Thank you,
brian.strandberg
Running an AUDIT should remove that error.  type in AUDIT, Fix errors detected say Y.  Now is a good time to PURGE your drawing too.
Hope this helps!
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
