Civil 3D Forum
Volumes Dashboard Default Printer (MIME then error)
2 REPLIES 2
mboyce
181 Views, 2 Replies
I have run into a problem where a coworker selected and option given to him in the report generator for the volumes dashboard as print to Bluebeam PDF and now every time he prints a window that says "MIME" with a progress bar for "converting" appears then there is an error message, but no report.
I have never encountered it before and I can't get Civil 3d to let me select a printer other than xml on my workstation. Does this need a reinstall to fix? I have been searching the web forever now with no luck.
Labels (1)
2 REPLIES 2
SoaresASBCAD
in reply to: mboyce
mboyce
in reply to: SoaresASBCAD
This does not explain how to change the output from xml to pdf or a physical printer.
I already know how to use the dashboard but I can't change the default output. My computer works fine but a coworkers computer goes MIME:ERROR then crashes. I am sure if we forget how to take volumes this will be very useful!
There is a button in the image that is shaped like a "?" that can also navigate to this page and more data so anything there I already understand
Rail Community
