Volume of multiple subsurface layers
I have recreated a corridor from Tender data for pricing a project. One of the items that has been requested from me is the volume of the different layers of material to be removed so that we can properly balance the cut and fill or be aware of the need to import/export material.
To simplify things I have condensed the TP and BH data into 3 layers. Topsoil, acceptable fill material (mostly sandy clays with cobles) and rock. The topsoil will not be used as fill material, only the other 2 layers. I have created a surface for existing ground level, a surface for top of fill material (using a volume surface between existing ground and depth to acceptable fill material), and a surface for top of rock (using volume surface between existing ground and depth to rock). So now on my profile I have 3 surface profiles for the different material. Looks good.
My issue now is how to calculate the volumes of the 3 materials. What is the best way to do this. If I create a corridor with daylight to EG I can get overall cut and fill to existing ground. Do I now also need to create corridors with daylight to the other materials, disregard the fill and take the cut areas away from each other? Will I instead do this with volume surfaces in some way? Is it best to use materials and sample lines (my experience with this side of things is lacking)? I just want the quickest way that will give a good approximation as I need to have this in by the end of the week. I also have a feeling there will be a few more of these coming up so I really need to learn how to do this properly.
Thanks in advance for any help in this area.
