I have an existing ground surface and a finish ground surface. I have sample lines along an alignment and sections showing cut and fill.
What I need is to extract the values for the cut and fill areas for each section. I wouldn't mind taking all the data in some sort of .csv (or something) and carving out what I need, but I'm having trouble finding a way to do that.
Thanks, gurus.
Solved by Jay_B. Go to Solution.
Start by creating a Materials List and then Generate a volume report .
Then, assuming the Xml report produces what your after, Rt. click > select all in browser > Copy & Paste to excel & format as desired, is one method.
Oh. I missed the "Display XML report" checkbox. (C3D 2016). Before, I had just generated a volume report that pops up in internet explorer and couldn't copy/paste the values anywhere.
The .xml file allows the copy/paste. That's a lot of weeding to get my values, but it'll do.
Thanks.
