Volume calculation limited to corridor
m.kolek82
m.kolek82
Hi. I'm new in C3d and I've problem to calculate earthworks volume. I've got an EG surface which is simple ground surface. I've also earthoworks surface. When I create material list I  add those two surfaces to calculation. Is there an option to calculate volumes based on thist two surfaces but limited to corridor? I add drawing to display what i want to do. Sorry if there was similar problem but I couldn't find it.
Jeew-m
Dear friend,
Do you have boundaries applied to final corridor top and bottom surfaces. If you do that you will get which you want.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
m.kolek82
I do have boundaries and still it calculate total volume of earthowork, not limited to corridor. Maybe I did something wrong, but I followed tutorials (I have complicated assembly done by myself and a lot of offset alignements).
m.kolek82
Problem SOLVED. I didn't know that I can add third surface to material list :). 2 days of trying almost everything and some simple thing defeat me 🙂 Thx for answer anyway.
