Viewport reference system grid outside the viewport
Mohamed.E.Salem
Mohamed.E.Salem
Hi all,
I faced a problem  while using the reference system to show the grid on the viewport. The problem is that the grid lines go outside the viewport as shown below using civil 2022. I tried to repeat the process with different files using civil 3d 2019, I got the same result.  Can anyone help me solve this issue?
Pointdump
Hi Mohamed,
Never seen that before. Can you post your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
tcorey
If, from Paperspace, you type REGENALL. Do the extended lines go away? No? Turn off Hardware Acceleration.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Mohamed.E.Salem
The file contains sensitive data that I have no permission to share it. Additionally, REGENALL has no effect, and the turn off Hardware Acceleration is not active as shown below
samir.rezk
Autodesk Support
Autodesk Support
Hi @Mohamed.E.Salem
Try setting the viewport type to Undefined from the AutoCAD properties palette
also the viewport object should be a rectangular viewport (not a viewport created from a Polyline)
Samir Rezk
Technical Support Specialist
