View Frames
View Frames
Automohan
View Frames
Automohan
Dear Colleagues,
There are 4 alignments, Main Alignment A with the service roads left & right as well as shown in the above Image
This is done by simple AutoCAD manually, to cover all the alignments with 1:1000 scale (A1), but if I want to do the same by civil 3d "View Frame"
it ask only one alignment at the time [I don't thing it will cover all the alignment]
I am using civil 3d 2014
I look forward to hear from you as soon as possible
thanks
Mohan
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
The ViewFrame command centers the frame along the selected alignment, yes this can only be one alignment.
But after the frames are generated you can reposition the frames however you like.
Also note, the size of the view frame is based on the size of the profile viewport and scale in the referenced template drawing.
