Civil 3D Forum
Very disturbing xref bug
5 REPLIES 5
bcsurvey
284 Views, 5 Replies
Over the last few months I have experienced several worrisome occurrences of an xref "shifting", but with insertion point, x/y/z scale, and units all matching the host drawing - all these established from the point of referencing.  This has occurred with 2 separate projects, on 2 separate machines, on two versions (2022 and 2024).   The only solution I've found is to detach and reattach, which blows out all xref overrides.  The shift is about a foot or two.
Has anybody else experienced this?  Is there a TS'ing step that I'm not utilizing?
Civil 3D 2019 (6.1)
Windows 10 Pro (21H2)
(i7-11850H @ 2.50 GHz)
32GB RAM
NVIDIA RTX A2000
5 REPLIES 5
brian.strandberg
in reply to: bcsurvey
I don't think I have seen this but I can give you a couple of potential causes.  Based on what you are describing, it sounds like this.
Often times people will try to select objects and accidently drag an object (xref) over a bit.  One way you can avoid this is to use the XREFLAYER setting and pick a layer for xrefs to be 'inserted' on.  (We use _XREF).  Once the xref is overlaid into the file, you can lock the _XREF layer.  That work fairly well for locking these down.
If you do that with an xref on a locked layer, you will get: 1 was on a locked layer.
I spend time on this forum because I enjoy Civil 3d and getting your likes.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Civil 3d to Street View: https://youtu.be/8Ima00-vLQA
Vote for My Idea:
https://forums.autodesk.com/t5/civil-3d-ideas/favorite-coordinate-zones/idi-p/12790928
m_kingdon
This is disturbing indeed.  The last thing anyone wants is unexplained creep in a design drawing.  I agree with @brian.strandberg  that locking layers might be a solution, I’d be interested to know if this stops the creep.
As for the cause of the creep, I am not sure.  Potentially a junior cad user?  I found one of our new users moving objects to select objects beneath because they did not know about the selection cycling feature.
Mike Kingdon
Civil 3D Zealot
Joe-Bouza
This will occur if the host drawing is set to feet and the xref is set to survey feet. But it does sound like and inadvertent flick
Why I cant explain but it does
Joe Bouza
fcernst
Try choosing Unitless for insertion scale in Units
Fred Ernst, PE
C3D 2025
Ernst Engineering
www.ernstengineering.com
lim.wendy
Hi Ryan,
Thank you for submitting your question in our discussion forums. I see you are visiting as a new member of the Civil 3D forum. Welcome to the Autodesk Community! Have you had a chance to review the suggestions our experts provided?
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
Rail Community
