I have been poking around for a while trying to find information on this, but I am curious if there is any way to exclude vehicle tracking information on new drawings.
It seems when I setup a new drawing and save it, then there is VT information associated on the backend right away. Others that don't have VT installed open this blank drawing and get a notification that they need to install VT to continue.
I understand that installing it on people's machines is a way around the issue, as is using VT purge. But instead of having to purge the info in all new drawings, is there anything we can do to just not have the backend info included in the first place?
Solved by Mike_Hurtado. Go to Solution.
Perhaps the template you're creating the blank drawings from has VT information already in it?
What happens if you open and save the attached drawing? Does it populate with vehicle tracking information?
When I saved a drawing created with this template there was no VT data associated. I will have a chat with our CAD manager to get this cleaned up. Thanks!
(I'll run a couple tests prior to marking as answer just in case something else comes up.)
