VBscript in Propertysets not working on some machines
ralstogj
ralstogj
Hi
I have vbscript that I am using in some of my propertysets that I use for labels, but on 3 machines in the office the scripts do not work. Seeing Civil3d has been installed at different times by downloading installs independently it seems unlikely that all 3 machines would have corrupt installs as per the suggested solution in this knowledge based article.
https://knowledge.autodesk.com/support/civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/VBA-s...
Before I go to the trouble of cleaning and reinstalled Civil3d on these machines I thought I would ask if anyone else has come across this issue and if there is a fix that does not require a full reinstall.
Regards
Justin Ralston
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
rl_jackson
Sorta nerdy here but check the SQL and updates and uninstall/reinstall those. Personally, anytime I've had an issue it was .NET or SQL (just saying), welcome to the Windows WORLD.
Rick Jackson
Survey CAD Technician VI
ralstogj
Rick
Thanks for making the suggestions. I did not try in the end as noticed that the machines at work were only updated to 2022.1.2 not 2022.1.3 as per my laptop at home. So did that update and also installed project explorer and now they seem to work fine with the file with the vbscript in the propertysets. Not certain if this was the fix but happy it is working for now. I did read something else about vbscripts not working if opened in two different versions of cad which we did do to check if the various was an issue seeing we have both 2021 and 2022 on the machines. Possibly after a restarting and only opening in the one version was the fix also.
Regards
Justin
Regards
Justin Ralston
