Civil 3D Forum
utility crossing table
11 REPLIES 11
Message 1 of 12
Joe-Bouza
1689 Views, 11 Replies
we have to prepare a utility crossing table for our Sanitary FM design that crosses existing utilities
 The table has the form
#, utility name, top of utility, bottom of utility, top of FM, bottom of FM, clear distance
I did this with pipe networks and surfaces
I used a null structure at each utility crossing the FM and can easily populate # , utility name,top, and bottom of utility. I couldn't use a reference text for the FM so I made a surface of the invert and an expression for the pipe height, assigned the surface to the nulls and populated that as top, and bottom of FM
How can I get the vertical separation from the FM to the Utility? I will entertain a work flow change, and would prefer not using an add-on that I don't have
Joe Bouza
11 REPLIES 11
Message 2 of 12
Dexterel
in reply to: Joe-Bouza
long shout. I so a app on Autodesk app store that label crossing pipes like you need. I don't know what are the app capabilities to make tables. Worth giving a search on app store.
Message 3 of 12
Joe-Bouza
I have that one. Alas, no table
Joe Bouza
Message 4 of 12
can you export the pipe data to excel?
there you can write an equation to calculate the clearance
and datalink back to cad . . ..
just a thought
Message 5 of 12
qnologi
I don't know if this what you're talking about, but I create "Pipe Clearance Tables" using Excel, then insert it using "Table", as a datalink.
I've attached somewhat of a unfinished "crude" example.
qnologi
Message 6 of 12
qnologi
in reply to: Dexterel
My company won't allow anyone to connect to the Exchange, so I guess I need to ask...
This "App" of which you speak...
I was wondering if they are able to store "ALL" pipe dimensions and specifications within its database to do an accurate assessment of for a utility crossing?
Or, is it up to the user to input such info. prior to use?
qnologi
Message 7 of 12
Joe-Bouza
thats an option.
Joe Bouza
Message 8 of 12
Joe-Bouza
in reply to: qnologi
The app I know of has no data base. It computes on the fly by selection and provides static text
Joe Bouza
Message 9 of 12
Joe-Bouza
That is what Im doing but would like to use a c3d table
Joe Bouza
Message 10 of 12
qnologi
Thought you might find this interesting... Smiley Wink
http://forums.autodesk.com/t5/autocad-civil-3d-ideas/idb-p/31/tab/most-recent
Regarding "Utility Crossings"
qnologi
Message 11 of 12
Joe-Bouza
Got my vote
Joe Bouza
Message 12 of 12
Add my vote to that item, too!!!
thank you
Rail Community
