Announcements
Utilities at elevation
Our field crew has located some underground utility lines-water, electric etc.. I'd like to set those lines to be at a specific level or drop from the surface so the waterline will display in a profile 42" below the surface elevation and the electric 24" below surface elevation.  I'm fooling around with pipe networks but am not familiar enough with that part of C3D to make any real headway. Any guidance is appreciated.
Joe-Bouza
you can create a FL at the plan location, set the elevation from surface then lower the FL the needed amount. then create pipe network from object. You probably want to set the nodes to be null structures that do not plot
Joe Bouza
Can you clarify by what you mean as "FL"?
MMcCall402
FL = Feature Line
You could also project the feature line into the profile view.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
