USE DYNAMO TO CONNECT TO CIVIL 3D LABEL
pperales2
pperales2
I am new to using Dynamo and I want to exploit its capabilities. I installed the CIVIL3DTOOLKIT, but it seems that there isn't a NOTE  LABEL node. Maybe I just do not understand what the node can be? Can someone give an explanation of what the CIVIL3D object node is and what it can do?
samir.rezk
Autodesk Support
Autodesk Support
Hi @pperales2
Take a look at the Camber package made by @mzjensen , it's a great new addition to Civil 3D Dynamo packages with many Label management functionality, including working with the note label. There is a Dynamo Forum thread for reaching out to the author as well: Camber Feedback Thread - Civil3D - Dynamo (dynamobim.com)
Hope this helps,
Samir Rezk
Technical Support Specialist
mzjensen
Thanks for the shoutout, Samir!
Zachri Jensen, PE   |
