Upgrading from 2025 to 2026
CoraForun
CoraForun
I'm looking for a tool that could help with the install.
How to move from 2025 to 2026 and keep all paths in the option window, including changes in the other tabs, pipe network catalog path as well with changes done to variables and whatnot? Like anything that is not default, how do you transfer?
We'd like to make the installation easier and create some kind of batch or script file that would retrieve the user's 2025 settings and transfer them to 2026.
Any help appreciated.
Cadguru42
Used to be A360 had this as a great option as a backup. Then in usual Autodesk fashion they removed that feature and never replaced it. Because Autodesk doesn't care about users anymore.
I just redo the settings and CUI every version update. But I don't use many customized settings precisely due to this same issue.
C3D 2024-2026
Windows 11
32GB RAM
AdammReilly
I don't know of any specific tools that do this. I typically export the profile to a *.arg file, and then manually edit that file to update all copies of the 2025 version to read 2026, and all the sub versioning (ACAD-8100:409 to ACAD-9100:409, for example). Then in the 2026 application, I'll import that modified arg file to create a new profile and test to verify all values carried over.
There are some settings that aren't stored in the profile, but for the most part, this is a quick and dirty way to carry your settings forward with minimal effort.
Adam Reilly
Civil 3D 2026
Creator A16 AI+ A3HVFG
Windows 11 Pro
AMD Ryzen AI 9 365 w/ Radeon 880M
LinkedIn
Group Leader badge
Austin CADD User Group
LinkedIn | Discord
Civil 3D Certified Professional
CoraForun
Thank you, I'll test this out.
