updating code set styles
Having viewed the several posts and replys regarding missing links between cut and fill daylights, I edited the code set style but now it seems to be locked on an earlier style.  Is there and update or something I forgot to do?
tcorey
There are multiple places where you set Code Set Style.
On the Corridor itself, Corridor Properties, Codes tab:
On the Assembly, Assembly Properties, Codes tab:
And in the Section Editor, under View/Edit Options.
Not setting all three of these the same can provide unexpected results.
"Why," you might ask, "does the program let you set the code set in so many places?" Good question. The reason: You might want to view the sections in the section viewer without labeling, while you might want labels in your cross sections views. You might or might not want to see labels, area fills, etc. when viewing the Assembly, while you want it different in section views.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
