My date stamp is also based on fields. My field eval is set to 31 which should update my file path/date string whether I plot, save, etc. I researched all of this on Friday and found a post to use the "All" in Fields, then "Date", then select the format. Everything was working fine and then I come to work today and the date string is no longer updating. Hence I went back on line and then happened to find the information concerning the updating, using fields, in text strings that I posted to this forum. Now this just shouldn't be rocket science here.We are trying to be productive. The automatic plot stamp is crap for use because depending on the size sheet, the printer, the scale you have to reorient and adjust which takes time and if you forget then you have to replot because you got in a hurry and didnt preview and if the drawing has a lot of images then the preview gets stuck and yes I am running 64 bit. kick **** computer.Breathe I just want accurate File path -date stamp. Any ideas??. I think I have an old Rtext but if I remmeber right they don't update except on insertion.
