I am already using Civil 3D 2022, Now I Purchase a new license which is Civil 3D 2023 and I want to use a new version 2023, what is the procedure for it? Do I have to uninstall the Civil 3D 2022 First? Or if I update it, it will automatically convert to Civil 3D 2023?
Screenshot attached for old versions of civil 3D installed in the system.
Solved by Jeew-m. Go to Solution.
If you have space on your hard drives, you can install 2023 without uninstalling others.
When running the software it will prompt you to apply for the license.
as you can see in the post by @Jeew-m . You can have multiple years installed at once. If you no longer use 2021. I'd suggest uninstalling that first. You may want to leave 2022 installed for a while in case there is a bug in 2023 and you have to revert to 2022 to accomplish something.
If you have customization. You might want to review "How Do I Migrate Customized Files?"
Allen Jessup
Engineering Specialist / CAD Manager
