@janis.prodnieks wrote:
I'm not sure what do you mean with ground units and grid unit
And that's your problem, you need to understand, ground and grid U-N-I-T-S are different. And top of that, you need to make the units geospatially accurate (whatever the units are determined to be) against a 'known' reference system.
BTW, if you're gonna ask the microstation guy for a new file, then ask to have it exported to kml, not dwg. Then import the kml to C3D. (Don't forget, before it's exported to kml, you must give the dgn a coordinate system beforehand.)
Microstation: To assign coordinate system go to Tools=>Geographic=>Open as Toolbox
Microstation: Export to kml.
The reason the country makes a difference is when you bring in the dgn linework into your AutoCAD drawing, the AuoCAD drawing needs to referenced against a known coordinate system. this means your drawing must be assigned a CS that's relevant to Latvia and not someplace else such as Nova Scotia or New Zealand.
Chicagolooper
