Unable to snap to Point nodes when Alignment nodes are at the same X,Y
hencoop
Advisor Advisor
hencoop
Hello all,
I have a relatively new installation of AutoCAD Civil 3D 2021 and I am no longer able to snap to Point nodes  (AECC_COGO_POINT object nodes) if an Alignment object has a node coincident at the location even when DRAWORDER has been used to bring all Points to the front of the Alignment.
This is not the behavior I am used to.  I can turn off the Alignment display (Change its style to _No Display); but, I'm wondering why does osnap not follow the object draworder when selecting objects?  Did something change?
Henry C. Francis
Authorized Autodesk Developer
Civil Design Specialist – Water & Wastewater Infrastructure
tcorey
Hello @hencoop ,
While hovering over the two nodes, pressing Tab will cycle between the alignment and the COGO Point. When you see the COGO Point highlighted, click the mouse.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
hencoop
@tcorey I've never had to do anything but snap to node and get whatever node was on top.  Pressing [Tab] works but I'm sure I've been able to use draworder in earlier versions so I don't need the extra keystroke(s) to snap to the object on top.  I'm just trying to find out if something changed or if C3D 2021 is behaving incorrectly.
Henry C. Francis
hencoop
@tcorey  Changing the Alignment style to _No Display eliminates the need to [Tab] to the node I want.  Since I have lots of nodes to snap to that are in this condition turning off the alignment display saves me time.
Henry C. Francis
