Unable to set Pressure Network Catalog
sfore
sfore
I'm using C3d 2023 with all updates. I'm unable to set Pressure Network Catalog in C3D 2023. The Catalog folder wasn't set so I managed to find out where they are and browsed out to C:\ProgramData\Autodesk\C3D 2023\enu\Pressure Pipes Catalog\Imperial. Below is the prompt I get plus a pic of the catalog locations. they are indeed there. I just can't access them. I was able to use them in C3d 2019, but this is the first time I've attempted to use them in 2023.
Kyle-Evans
I have seen this a few times, the fix was to Clean Reinstall Civil 3D.
I have also seen some random addon's for Civil 3D and Autocad/Revit that caused the issues.
MSchille-1994
Be sure to navigate one folder up from where you were at.
Attitude, not Aptitude, Determines Altitude
