Civil3d 2019
I remove points from a point groups used to build a surface. I update the point group. I manually rebuild the surface. Right click on surface name and Edit Surface Style; turn triangulation on --> triangulation still shows points deleted from point group are being used in the surface definition. Whiskey Tango Foxtrot, over?
Points 302 & 303 specifically excluded from point group ExGround:
Points 302, 303 do not appear in point group ExGround:
Point group is manually "updated," Surface is manually re-built, and yet point 303 is still being used. WTF?
I've got work stacked up. I'm behind. And I'm wasting time trying to debug problems like this. I'm losing money because of this BS.
I've also audited the drawing (found two errors, fixed, yet problem remains). I've closed and re-opened the drawing.
Grrrrr...
