unable to locate subassembly composer - Civil 3d 2022
Ross_S1
Ross_S1
I just installed Civil 3d 2022. I'm trying to locate the subassembly composer (to use it), but don't find it.   I have little or no experience using subassembly composer. I noticed previous versions of subassembly composer on my computer as a separate program from Civil 3D, but I don't see one for the 2022 install, even though the install window indicates that it has been installed. I'd appreciate getting pointed to how to access the subassembly composer (2022).
Thanks much,
samir_rezk
Hi @Ross_S1
When installing Civil 3D, there is an option (check box) to choose whether or not you want to install Subassembly Composer. You might have not installed it along with Clvil 3D! Run the installer again (you won’t need to re-install Civil 3D, just find the check box for SAC)
Hope this helps,
Samir Rezk
Technical Support Specialist
Ross_S1
Thanks, I verified this morning that I had the check box checked for subassembly composer. I downloaded the executable and ran it. I still don't find the 2022 subassembly composer. Is there any chance there isn't a 2022 subassembly composer and Autodesk is just using a 2021 subassembly composer? I do see a 2021 version on my computer. Below is a screenshot from yesterday.
