Unable to load part family: Comms ducting multiway
richardKTHG4
richardKTHG4
Hi All,
I just got this error when doing a pipe network. No modifications have been done to the catalogs.
Any idea how I reset them please?
Command: _AeccCreateNetworkFromObject
Select object or [Xref]:
Flow Direction [Ok/Reverse] <Ok>:
Unable to load part family: BT Manhole MRX401 Rectangular edge access
Unable to load part family: BT Manhole MRX402,405,410,411,412,413 Rectangular center access
Unable to load part family: BT Manhole MRX404 Rectangular edge access 2400x1200 2m height
Unable to load part family: BT Manholes MRX509-MRX513 Chamfered Rectangle shape
Unable to load part family: BT Manholes MRX810
Regards
Rich
M_c3d
This usually happens if you are pointed towards the wrong pipe catalog (i.e. the one you are looking at doesn't contain these parts). Check the catalog your civil 3d is pointing to and see if they contain these parts
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
richardKTHG4
Thanks for the reply, it looks some how the catalog has got altered and even the refresh commend does not seem to bring in the pipes I used to have.
Regards
Rich
M_c3d
I'm afraid if their gone they are gone, only way to get them back is via another PC that has them or a back up.
Are they the BT chambers from the OTB UKIE country kit? If so you can download them again and put them back in, if they have been customised its more problematic as you would need to re customise them
richardKTHG4
They where the ones with Autocad civil, I can not download the country as the IT police will not allow the PC I use to connect to the internet hence I need to ask all the questions at home and print out and take to the office. If I could down load the country kit I can take in on a USB get it scanned and then upload. (do not ask my why they are like this)
Thanks for the reply any way.
Regarsd
Rich
M_c3d
We all have experienced over zealous IT departments at some point!
Tell them that the UKIE country kit is an official part of the software made by Autodesk and you need it installed. It's 100% legit
