Unable to attach ditch to DaylightBench
soonhui
Advisor Advisor
soonhui
It does seem that Civil 3D doesn't support the attachment of ditch-- or any other subassembly-- after DaylightBench??
This is because that despite in the coding diagram in the help files there are "hook" points that I can use to attach subassembly, in reality I simply can't find any Point Code fro daylightbench, as shown in the below screenshot:
Other subassembly, OTOH, does contain a lot of Point, Link and Shape Codes.
You can use the drawing below to test.
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
essam-salah
it does support attach other SA after DaylightBench. (check pic below)
soonhui
Oh wait, I've found the point for me to attach! And like @essam-salah showed in the screenshot, it's that circle.
I'm not too sure what you are driving at.
  1. I need to attach a ditch after Daylight, but still, the problem of NO point code for me to attach is still there
  2. ShoulderWithSubbaseInteracedAndDitch is not exactly a "ditch" subassembly. Yes I do see that it's on the drawing as per your screenshot, floating at somewhere, but it's also not at all clear how can it be attached to my daylight subassembly.
Ngu Soon Hui
essam-salah
so, have your problem solved ?
soonhui
Yes
@essam-salah , but then, I can't seem to do it from API, see here.
Ngu Soon Hui
