HEELO DEAR ALL
1) I WANT TO TYPES OF SLOPE IN SINGLE CORRIDOR.IN PROJECT I NEED 2:1 FILL SLOPE FOR UPTO 3 METER FILL AND 1.5:1 FOR ABOVE 3 METER FILL
I WANT THAT MY ASSEMBLY PAVAMENT STRUCTURE SLOPE CHANGE AS REQUIRE SLOPE .
AS ATTACHED PICTURES
I USED CONDITIONAL CUT OR FILL BUT NOT WORKING ON MY SIDE
PLEASE SEE THE ATATHCED PICTURE FOR CLARITY
Solved by Jeew-m. Go to Solution.
Solved by imran_tamrahi. Go to Solution.
BUT KEEP IN MIND THAT I SECTION IF HEIGHT OF FILL IS 6 METERS I WILL USE ALL SLOPE OF 1.5 : 1 IN ROAD SECTION
IF HEIGHT I LESS THAN 3 METERS I WILL USED THE SLOPE OF 2:1 IN ROAD SECTION
AS ATTACHED IMAGES
THE SLOPE OF PAVAMENT STRUCTURE SHOULD BE AS FILL SLOPE
Dear Friend,
I think the conditional cut and fill sub assembly would help you in this case. According to your vertical height and slope you can measure the horizontal distance of each cut/fill condition to set up your conditional sub assemblies. Please refer the following video.
https://www.youtube.com/watch?v=S8Yckfwj03g
Thanks.
Dear Friend,
Please use the screen cast as a guide and get what you need. Hope this will clear you.
dear sir i am attaching the file please i am not able to consider the problum in my file targets are set but not reflecting in section view
Dear Friend,
Please watch the screen cast carefully. I have added a daylight sub assembly after the conditional cut and fill. You haven't add that on your assembly. Also check all the parameters (lengths, heights) because what I have done is just an example.
Thanks.
bundles of thank dear very very thankful to you for kind reply i have done
but one issue is as it is that
my i using assembly with slope not vertical is there any way that my slop change automatically as my assembly slope is?
regards and one again a lot of thanks
