Two different point styles in one drawing?
sam.stibbs
sam.stibbs
Basically I have two sets of point files in .gml format and I want to bring them in as assign them different point styles. Is there a way to do this or is it the case that with points you can only apply one point style using the PTYPE command?
M_c3d
You can apply as many different styles as you wish, you can either do this before or after you bring in the points;
  • to do it before you need to change the default style that it comes in as on the settings tab of toolspace
  • to do it after go to point group properties > information > point style
BushW
Hello @sam.stibbs
@M_c3d is correct his reply to you about having many different point style based on point groups. Here are some videos below that demonstrate how to change your point display.
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit and thank you for doing so, and I'm here to help.
Wendell Bush
Civil Infrastructure Technical Support Specialist
neilyj666
PTYPE is for vanilla Auto CAD points rather than civil 3D cogo points.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
BushW
Hello @sam.stibbs
I just wanted to follow up here, any thoughts on my previous post? Thanks for the update!
Best Regards,
Wendell
Wendell Bush
