Two aliases will not commit
CovenStine
CovenStine
I've added a few aliases, but a couple of my changes won't commit no matter what I've tried; and since these commands are (mostly) C3D specific, I figured the question should be here (on c3D 2023, up-to-date).
I use FeatureLines a bit, so it's been convenient to setup some commands for quickly accessing FeatureLine specific commands.
I've set
FO to OffsetFeature
FD to DrawFeatureLine
FC to CreateFeatureLine
FCA to CreateFeaturLinefromAlign[ments]
FB to BreakFeatures
FT to TrimFeatures
FJ to JoinFeatures
FE to QuickEditFeatureElevs
FG to SetFeatureGrade
FS to FeatureElevsFromSurf
PII to InsertFeaturePI
PID to DeleteFeatuePI
Because none of these commands are in the Alias Command List by default, all of these needed to be added to alias.pjc, which has been done successfully*, and I've successfully created aliases to all but two of these commands. (*yes, as admin in win11)
No matter how many times I reset FC CreateFeatureLine and FS to FeatureElevsFromSurf, AC is ignoring these changes (after restarts, saves, new sessions, etc.)
Every time I use FC, I get "Unknown Command FC, press F1 for help," and every time I try FS, autocad activates 'FSMODE.
This is rather driving me bats, because at a previous employer these aliases were set as part of the standard AutoCAD configuration file that was rolled out to all users... so I can't understand why it won't work for me.
I apologize if this has been asked and answered elsewhere, I've tried searching but I think I'm wording my question wrong for any good results.
Thanks y'all!
AllenJessup
It looks like FS may be a existing full command name. See:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Command-Aliases-do...
I don't know about FC. You might try usijng AeccCreateFeatureLines.
I've had 3rd party Add-ins hijack some Aliases.
You might try adding the Alias commands to an acaddoc.lsp file. See:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Some-command-alias...
Allen Jessup
CAD Manager - Designer
CovenStine
Thanks!
I would've sworn we could override set aliases, but you're right- FS seems to be the ENTIRE command, and seemingly can't be overwritten.
Your response also showed me my mistake- I'd set FC to "CreateFeatureline" instead of "CreateFeaturelines"
SMH
Thanks for your help, Allen!
chriscowgill7373
I have these in my startup lisp.  I have code in my acad.pgp file as well, but like you said FS overrides my function.  I'm guessing that years ago, it may have worked, and then newer functions were added that caused the pgp versions to no longer function and I never removed them when I switched to LISP.
(defun c:FQ ()
(command-s "AeccQuickEditFeatureElevs")
(defun c:FC ()
(command-s "AeccCreateFeatureLines")
(defun c:FG ()
(command-s "AeccSetFeatureGrade")
(defun c:FP ()
(command-s "AeccInsertFeaturePI")
(defun c:FJ ()
(command-s "AeccJoinFeatures")
(defun c:FPD ()
(command-s "AeccDeleteFeaturePI")
(defun c:FE ()
(command-s "AeccInsertFeatureElevPoint")
(defun c:FED ()
(command-s "AeccDeleteFeatureElevPoint")
(defun c:FS ()
(command-s "AeccFeatureElevsFromSurf")
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
