Turning one surface on at a time.
I have about 6 surfaces in a drawing, when I change the definition for one it changes the definition for all of them. as well as if I turn one off it turns all them off. Is there a way to isolate the surfaces and there properties? Does anyone know why it would be doing this?
Jeff_M
Create/Assign different styles for each surface.
Jeff_M, also a frequent Swamper
Thanks Jeff.
jmayo-EE
Or tell your style to use layer zero and have the Drawing Settings, Layer settings tab create the layers. With this you can use all of your layer commands, off, on , freeze, thaw, isolate, etc.
John Mayo
doni49
We have one style named _No Display.  On the display tab, EVERYTHING is turned off.  This way, we just assign that style to any surface we don't want to see.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
