Turn of warming offset label
qixing_chenZEV3X
qixing_chenZEV3X
Greeting,
Does anyone know another way to turn off this warming? Maybe turn off its layer or object.
I know another option is to use options under solution tips  drafting
Thank you for your help!
rl_jackson
There's no other option that I'm aware of just going to the Options - AEC tab, and uncheck Drafting in the lower left of the dialogue.
Rick Jackson
Survey CAD Technician VI
samir.rezk
Autodesk Support
Autodesk Support
Hi @qixing_chenZEV3X
The i in a circle symbol indicates that you have overridden the label style in some way, to turn it off, go to the Annotate ribbon tab > Label Text panel
On a side note, the OPTIONS > AEC Editor > Solution Tips setting control the display of the i in a triangle warning indicating the model does not meet the design standard (as an example, a non-tangent alignment segment or an open connection in a pressure network)
Hope this helps
Samir Rezk
Technical Support Specialist
chriscowgill7373
I wish you could just make it smaller.  I find it critical to leave these warnings on, but just not have them be so intrusive.  I very much want to know that a label has been manually modified, you can get into some big trouble if someone is making a note say what they want it to, and not allowing the design to fill in that information.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
