Trouble with T-Intersection Assemblies and Subassemblies
I have a couple issues with a T-intersection and assemblies.  I have 4 sections circled in the attached photo, which each represents problem (CAD Intersection Help.jpg).
1.  This area is a half road assembly (cannot be full road due to incoming road).  When it goes from full road to half road as it does on both ends, there is a split in the road where the change from one assembly to the other occurs (see CAD Intersection Help 3.jpg)
2.  Even though the curb was deleted on the subassembly, it appears that there is still some remaining.  Also, like above, there is a gap where the outer edge of the road does not connect.
3.  Similar to #2, but the cut/fill is doing something strange.  I have tried different subassemblies but cannot get it to change.  I was thinking this has something to do with the targeting (CAD Intersection Help 2.jpg).
4.  Same as #1, going to half section of road to full and there is a strange cut across the entire road with a small gap.
Any info or suggestions would be great.  Maybe I need to create a new intersection without the curb fillets?
Adam
Solved the curves by editing the curve return parameters and offsets.
