Civil 3D Forum
Triangles Ignoring Points from Feature lines
3 REPLIES 3
brendan.collum
172 Views, 3 Replies
The Tin Triangles from one feature line are ignoring the next feature line. Even 2 points 1' apart will TIN to a different point +100' away. I have removed all surface edits except for the breaklines being added. Grading becomes a completely manual operation and exponential inflates production time. Has anyone found a solution for this persistent problem yet?image.png
Labels (1)
3 REPLIES 3
Try adding a point on the blue line where the odd jump is.
Sometimes you need to have corresponding points on the adjacent featurelines to triangulate correctly.
Mike
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Usually when I see this is that someone has added a bunch of edits to the surface that is obscuring the feature lines.  Take a look at this video I did, Civil 3d My surface is ignoring the feature lines - YouTube
Thanks.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
tcorey
in reply to: brendan.collum
Not having the .dwg file, I can only attempt an answer. If that is a breakline running ne/sw, those long triangles could be caused by the distance between points along the polyline or feature line.
You don't need to add additional points to the breakline objects themselves, but you should consider adding a supplementing factor to the breakline during the Add Breaklines function.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
