TREELINE linetype not plotting correctly
pjohnson
pjohnson
When I plot a single sheet to a PDF the TREELINE linetype plots correctly.  But if I publish multiple sheets the TREELINE linetype plots as dotted. See attached.
Any ideas on how to fix this?
tcorey
Show us your Plot dialog from AutoCAD and show us your Publish dialog. Be sure to select a sheet from the list, so that the sheet output properties are added to the Selected sheet details.
A screen shot of your ctb or stb and is it the same for both plots?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
pjohnson
See attached.
Where in the publish dialog box do you set the plot style table?
jroot
We get this problem sometimes too, never figured out why.
Change the linetype for the tree layers so they are using something else (and other references to the tree linetype), then PURGE the linetype. Re-insert it from a clean dwg and it might work. If all else fails we just use REVCLOUD.
pjohnson
Thanks.
I was able to fix it by just closing out of CAD and reopening the drawing?!? But good to know for the future.
topknot
I've had the same issue with WALL-BOULDER over the years. I've never figured it out. I'm having the same issue now. Works fine with PLOT, but it only shows dots in PUBLISH. I'd love to hear anyone with a solution. WALL-BOULDER uses a shape from AECCLAND.shx.
