Transition Grade smoothness
qchenTPPXV
qchenTPPXV
Greeting,
I  created a transition grading, the left side slope is 2:1 and the right is 1.5:1, and used grade to elevation. But find out the toe of the slope isn't very smooth. Is there a way to make it better? Just for visualization purpose.
Mike.M.Carlson
Once you create the transition grading there are little grips that are available along the feature lines to allow you to increase the transition distance to help smooth that abrupt change you're seeing. It looks like Civil 3D is giving you the "best" it could solve given your initial parameters. Try using the grading object transition diamond-shaped grips to get a better feel visually for what is actually possible for your design.
Another option is to build a corridor and try the new region transition feature https://youtu.be/n7MoTxSXclo?si=p2EYIIsFU6voGKZr or build a custom subassembly in Subassembly Composer https://youtu.be/W-f4Ep7TXyE?si=7FuJkT3WiqobR9Ma.
Both give good control for dialing in transitions.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
qchenTPPXV
Thank you very much Mike.
One follow-up question, do you know where to find grip for the feature line? I didn't find it.
[cid:6f3bd0ea-9185-4468-b9c5-93d4db2286c6]
Mike.M.Carlson
It wouldn’t be on the actual feature line but rather look for the last straight-segment grading object projections you should see a slider along the bottom you can grip and pull away from initial transition / normal grading interface. I am away from my laptop or otherwise would show a snip.
Michael M. Carlson
CADD Manager
qchenTPPXV
Thank you. It would be appreciated to show a snip when you have a chance.
Mike.M.Carlson
I checked your file. I see the grading object but it is limited to the object itself. The surface you have isn't built from a traditional grading object in the area you have the issue. Please check the Surface definition and track down what is driving the builds. All three surfaces in the file do not have a Grading Object as the surface definition.
By the way this is how the grading object transition grips look:
Michael M. Carlson
CADD Manager
qchenTPPXV
I used polyline to create these transition gradings from one file and the detached surface and paste them in the this file. I checked the original file and couldn't find the grips. Do you mind show me how you did it? I am fairly new to C3D. Thank you very much.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
