Hi all,
Now that I have your attention, I am seeking your great advice once again and truly appreciate your effort.
My situation:
Engineering has proceeded with their design (from conceptual) and it is not on the same basis as our survey work. I would like to rotate and move the design to the survey drawing's basis. There are common points (this is an old project that has been brought back to life).
I thought I would seek the advice from those that know before I proceed. I have copied engineering's drawing and am going to experiment. I tried to search for information and came across a transformation process using Map 3D. I will pursue that if necessary. My goal is not to mess up the Civil 3D objects - surface, sections, profiles, etc. At some point the surveyors will have to field stake the design and would rather continue to use the survey basis.
What would you recommend?
Thanks in advance,
Norman
