TRANSFORM FROM PDF TO DWG
MiguelGT17
MiguelGT17
NEED TO OPEN A PDF DOCUMENT IN AUTOCAD CIVIL 3D
what are the steps?, is there any web do that for free?
HELP PLS, I WOULD APRECIATTE IT
schroederC3D
Hi Miguel,
Use PDFIMPORT to convert to CAD elements.  If this answers your question, please mark it solved!
Thanks!
Reply Syntax?
Command (Uppercase): TRIM, Variable (Italicized): MSLTSCALE, Civil 3D Object (Within brackets): [SITE]
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Please support my Idea to revert the forum format to the old one: https://forums.autodesk.com/t5/community-ideas/revert-to-old-forum-layout/idi-p/7917987
tboehler
If you just want the PDF in the CAD file as a background (image) you can attach it through the xref manager.
PDFATTACH
Not an import - no entities - just an image.  The prevoius post (PDFIMPORT) will get you entites (depending on the PDF creation).  PDFIMPORT is new to 2017 and 2018 and a great command.
