Civil 3D Forum
Top of Structure Grip Edits
4 REPLIES 4
bGacke
162 Views, 4 Replies
When I select the top of structure grip in profile views, the key-in for an elevation pops up (see picture below). Entering an elevation just moves the top of the structure to some random elevation that is anything but the elevation I typed in. Is there any way to fix this issue? Seems pointless to give me the option to enter a value if that value is then ignored.
Labels (1)
4 REPLIES 4
brian.strandberg
in reply to: bGacke
That is kind of strange, if you are able please post the drawing.  I suspect that you are not in the world coordinate system, and that is goofing things up for you.  Type in UCS <enter> <enter> to set to world, and see if it still acts weird.
Thanks.
I spend time on this forum because I enjoy Civil 3d and getting your likes.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Civil 3d to Street View: https://youtu.be/8Ima00-vLQA
Vote for My Idea:
https://forums.autodesk.com/t5/civil-3d-ideas/favorite-coordinate-zones/idi-p/12790928
MMcCall402
in reply to: bGacke
Could be this:
Structures have a built-in pipe clearance value that limits how close a pipe can get to the top of the structure.  Structures will discard an entered top elevation if its violates this limit and replace it.  (I think it goes to the lowest value possible based on the connected pipes)   So, your connected pipe elevations could be overriding your structure top values.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
brianjg78
in reply to: MMcCall402
Yeah, I am familiar with that. That is not the case here though.
Seems its a problem with this specific file. I tried it in another and it works fine. I tried setting to world UCS (99% sure it was already anyway) and that didnt help. Any other suggestions? I tried AUDIT on the file already.
lim.wendy
in reply to: bGacke
Hi Brian,
Thanks for reaching out to the forum. Are you able to share the dwg?
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
Rail Community
