Toolbox Reports failing to execute in new drawings not using company template
smarkewinski
Observer Observer
Message 1 of 1
smarkewinski
Observer
Observer
I recently started a new job with a company doing civil survey with an absolute disaster of a template (text issues causing hangs, over a dozen object data tables still attached, etc.). In the process of setting up a template from scratch I found that I could not run any of the reports from the toolbox in drawings created with the new template. This appears to be an issue when creating a drawing without a template, as well as with the standard templates: acad.dwt, _Autodesk Civil 3D (Imperial) NCS.dwt. This occurs using my profile loaded using a shortcut as well as the default Civil 3D profile loaded when launching from the start menu without the additional settings. When starting a new drawing or opening an existing drawing created with the company template all of the reports run fine. Is there a way of ensuring that a new template will include the reports without having to try and update the existing template?
Running Civil3D 2020.6.1 Update
Error returned when trying to run XML reports is "Failed to execute 'General Legal Description for Parcels - CCW'.
Replies (0)
