Titleblock - Diesal Expresion
Oli
Oli
Hi
I'm hoping someone can help me with a custom diesal expression for my new title block; I use the following filename format:
SX000_DDD_000_Blah Blah /  SX000_BCH_000_Blah Blah
If DDD I'd like and Output of Design
if BCH I'd Like an Output of Bench
Is there a way of doing this?
jmayo-EE
Make an rtxext object for each case and manually delete the one you don't need when creating sheets...Unfortunately without an IF statement it won't work and I don't believe the diesel will do that.
John Mayo
Oli
Thanks John,
Can you do an IF in LISP?
jmayo-EE
I would bet you could do this with lisp but the experts for this tool are over here,
http://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
and here,
http://forums.autodesk.com/t5/autocad-civil-3d-customization/bd-p/190
John Mayo
doni49
A lisp routine could be created that runs everytime you open a file.  The routine could update one of the user setvars (setvar "users1" "bench") for example.
Then a deisel expression could read the value of that setvar.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
