I cannot figure out how to get the parts list that shows up in the Settings tab in ToolSpace to be the same one as shown when I edit the Network. What can I try?
With 2015+ versions of civil3d there are two parts lists locations under settings. One is for Pipe Networks and the other is for Pressure Networks. Could it be you are looking at the parts for the other category? Also, do you have more than one drawing open. It could be that you are seeing the settings from another drawing that has different parts lists.
I attached two images of what I am seeing. It's in the same drawing. The first one is under toolspace-settings. The second is the Newtwork edit. The lists aren't the same.
Can you include an image of the entire list provided for the Edit Network structures? All that's shown is the Null Structure at the top of both lists... so you're not really showing the difference.
Thanks!
