The beginning of the project starts after alignment begins, how do I change the station label at this point to 0+00, without removing the previous alignments entities.
Mitchell_A_Decelles
Mitchell_A_Decelles
Image shows that I want to change the station label at this location to 0+00, though it is in the middle of my alignment.
tr.armour86
You can adjust where 0+00 is through Alignment Properties, under the Station Control tab.
zshakir
You can do that with Dynamo, link below will be good resource to your isuue
https://forum.dynamobim.com/t/set-alignment-start-station/67310
rl_jackson
Depending on weather you want to have the station labels all be positive if the project was to be extended at a later date, a station equation can also handle this while providing stations along the entire alignment. You would just need to create a AHEAD and BACK STATION EQUATION and add it to the label set. This would be accomplished in the lower portion of the dialogue that @tr.armour86 displayed.
Rick Jackson
Survey CAD Technician VI
