Text SHX Files Missing in Text Style Manager Despite File Path Being Set
rorodriguez9FB8K
Observer Observer
rorodriguez9FB8K
Observer
Observer
I have company shx fonts that we use, so I set up the file path by going to Options > Support File Search Path > [insert file path here]
The issue is the defined text styles that use company .shx files all have a warning symbol next to them or aren't even included in the drop-down list (see 1st picture). If I have an MTEXT where I can manually edit the text, the drop down list in the Text Editor > Formatting tab has all the .shx files from the directory path (see 2nd picture. For example the text style SLEROY should reference the SLEROY.shx file that's in the fonts folder but it shows there's an error/missing. But if I edit an MTEXT line and look at the drop down for fonts, all the .shx files are there, including SLEROY.shx. How do I make sure I can use the .shx files when creating a text style? I also want a regular Leroy font that isn't slanted but it's not even in the drop down menu in the Text Style Manager. It's a pain to manually edit each one and designate the correct font.
tcorey
Maybe it's a BigFont. In the Style dialog, check the box to use BigFont.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
rorodriguez9FB8K
Observer
Observer
Good suggestion, but don't think it's the correct solution. It removes all of the True Type Fonts installed on Windows and shows all the shx files that were there before in the Text Style Manager, but I'm still missing the other 30+ other .shx fonts.
pendean
Community Legend
Community Legend
Do you just need to restart C3D after pathing the fonts then checking your session to ensure they are found with a quick lisp like this
(findfile "FONTNAMEHERE.SHX")
Otherwise... ZIP then share your SHX font files here for examination by others.
