text disappears when using the rotate and move command.
nmigliori
Message 1 of 24
nmigliori
hiya! my text is dissapearting when i use the move and rotate command. it also dissapears when i drag by a grip - my dragmode is set to auto and i've turned on and off my hardware acceleration to no effect. are there other system variables that i could change to fix this? other co-workers open up the same drawing and dont have the problem, so it seems like its something within my cad settings but i cant find it... help
Replies (23)
Message 2 of 24
Pointdump
Hi @nmigliori,
"other co-workers open up the same drawing and don't have the problem..."
Do you have this problem with other drawings, or just this one?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 24
nmigliori
@Pointdump  All drawings.
Message 4 of 24
rl_jackson
Graphics Card maybe?
Rick Jackson
Survey CAD Technician VI
Message 5 of 24
jroot
Sometimes when I MOVE text it disappears because my OSNAPS are on and the text get sent way far away to the end of a line 🙂
But anyway- I would say try an audit but you say it's in all dwgs.  Do you use annotative text?
Message 6 of 24
AllenJessup
Does Regen bring it back. After the text disappears. Where does Zoom > Object > Previous take you?
Have you tried turning off Hardware acceleration?
Allen Jessup
CAD Manager - Designer
Message 7 of 24
brianlevi
Observer
Observer
I'm having the same issue with a new Lenovo Legion, Win 11 Pro, NVIDIA GeForce RTX 3070 graphics card, C3D, 2022 current updates on both CAD and Windows.
This is driving me insane. Regen does nothing. I have to undo and then run an audit every time this I have this issue, which is 10 - 20 times a day.
Anyone else having this problem?
Message 8 of 24
nmigliori
Yeah never found a solution - I just reinstalled AutoCAD to fix it ¯\_(ツ)_/¯
Message 9 of 24
brianlevi
Observer
Observer
Thanks for that. I really didn't want to have to do a fresh install mid project, but..... here we go again....
Message 10 of 24
Zlatislav.atanasov
You can try updating your video card drivers.
My personal blog - AutoCAD and AutoCAD Civil 3D hidden Secrets and great tips in one place -
https://skillamplifier.com/
Amplify your skills to a new level!
Message 11 of 24
rl_jackson
This may also have something to do with how windows is handling fonts. Especially if there true-type fonts that are in play.
Rick Jackson
Message 12 of 24
GARY
YES, I too have the same issue. when moving or editing text, you can convert it to mtext and the problem will stop.
I don't have an issue when opening the same drawing on my laptop which has a i9 windows 10 pro and others don't seem to have an issue either.
btw, all updates and drivers are current.
p620 thinkstation
AMD Ryzen Threadripper PRO 3945WX 12-Cores 4.00 GHz
windows 10 pro
nvidia quadro p2200
AutoCad 2022.1.2
thanks
Message 13 of 24
Neilw_05
There is a variable that makes text process faster by simplifying the display. I think it is FASTTEXT or similar.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 14 of 24
Neilw_05
The variable is QTEXT. Probably not your issue but worthwhile to check it.
WIN 10 64 PRO
Message 15 of 24
GARY
Thank you, Neil,
I have not had an issue where I needed to use "QTEXT", but that tip looks very useful. as far the 'fasttext' autocad has a command for which I can't remember either. I did try it but didn't stop it from happening on this machine.
I am wondering if it has to do with a processor type, I can open the same drawing using my laptop with a I9 or my older desktop with a I5 and don't have "TEXT" that will disappear when editing it. My work around is to convert text into mtext for now.
cheers
Message 16 of 24
Neilw_05
It sounds like a video driver issue as was suggested by Mr Zlatislav. Do a search to see if you can find an update.
One other suggestion: change the font used in the text style to a standard Autocad font (i.e. Simplex). It may be your style is using a font that has issues.
WIN 10 64 PRO
Message 17 of 24
rakingCT55F
I have this same issue using Civil 3D 2022, Text disappears and comes back with regen but can't be moved or deleted.
Message 18 of 24
C3D_Handyman
I am seeing this issue also on one of my users computer. No one else is seeing this. This user has left running osnaps off and it still happened. This is user is up to date in Windows and C3D 2022 and ACAD 2022 updates. Video drive is using the latest Autodesk Certified driver for the card and I have also tried it with the latest driver for this card.
What is madding about this error is that it can't be repeated on demand. The user was finally able to capture the issue on video I have attached it. The only way we have found to clear the issue is to close out of Civil 3D but try doing that 5 or 6 times a day. We are about ready to reinstall Civil 3D but would prefer not too.
Message 19 of 24
jherman7QTNM
@C3D_Handyman I am having this exact same issue.
Message 20 of 24
sjeffares
Community Visitor
Community Visitor
Same Issue. mtext works and also doing and Audit works for a while.
