Text box with background mask showing up as white block in plot preview
When I preview a plot in Civil3D 2018, any text that has a background mask is showing up as a solid white box in the plot preview.  When I change the FILLMODE from 1 to 0, the text shows up on plot preview, but the background mask no longer works.  I have attached a file with an example.
Any text without a background mask shows up fine in the plot preview.
Any ideas on what may be causing this??
Derek
Alfred.NESWADBA
And if you plot to PDF instead just doing a preview, same issue?
Can you please start command _ABOUT and show us a screenshot from that dialog?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred,
See attached for a screenshot of the _About command.
Derek
Alfred.NESWADBA
please install all updates, neither AutoCAD nor Map3D nor Civil3D is updated.
The _ABOUT dialog should show that release (currently).
- alfred -
Alfred NESWADBA
