Target behavior in Subassembly Composer.
AllenJessup
Mentor Mentor
AllenJessup
In the Subassembly Composer. I have a Horizontal Target in P1 designating the bottom of curb which is the ETW. in the preview. No matter if the offset is positive or negative you always see it as a positive X offset. Is that the way it will behave in an Assembly or is it just an artifact in the Composer?
Also. I'm surprised you can only set targets on points created by Slope or by Angel. If it is an override on the X or the Y. Why can't you use a targeted on a point created by  Delta X and Delta Y. Just wondering.
PKT attached
Allen Jessup
CAD Manager - Designer
BrianHailey
If you change it to "Slope and Delta X" seems to fix it. Not sure why the other option doesn't work.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
AllenJessup
Thank you! That works.
Don't know why either.
Allen Jessup
